I kept on trying to install this update that I got as a notification. But when I tried installing, it was showing me the windowsupdate_c0000135 error code and was showing me that sqmapi.dll file was missing. Help me, please.
Fix For Windowsupdate_c0000135
Run the system file checker to replace the incorrect version of the files.
To run the System File Checker:
• Go to CMD and run the program as administrator.
• Enter the following command and press enter the command:
– Scf/scannow.
This code would run the scan for a while and will replace all the incorrect files and fix them.
Sometimes it may prompt you to insert your windows installer CD in the mid-way of the installation process. So you must have a drive that consists of the windows installer.
After this process, you can install the update.
