Two days ago, my Xbox live has expired, and yesterday I was trying to buy a one-month subscription, but I was continuously showing this Xbox status code 80190864 error code. I tried it for five to six times, but it was continuously showing this error. How can I fix this error?
Fix For Xbox Status Code 80190864 Error
This Xbox status code 80190864 occurs either when your card is expired or declined or you have purchased too much stuff using your Microsoft Account. It can also happen when your account doesn’t have sufficient balance. The first thing you can do is to make sure that your debit/credit card is working. The second thing is to check that you have sufficient balance. You should contact your credit card company and file your complaint. The third thing you can try is to change the method of payment to your Xbox live subscription. You can follow these steps-
- Sign in to the ‘Services and subscriptions page’ using your Microsoft account.
- Search for the ‘Xbox subscription.’
- Select ‘Change how you pay.’
- Input the new payment option.
- Click on ‘Next.’
Before adding the new payment option, you should remove the previous payment option.
