A Cameron
Posted on - 09/15/2016
Your laptop contains all your important assignments and data files. if the laptop crashes down or doesn’t boot into your operating system, it is a heart break. To solve these issues we need to fix our gateway laptop. How to fix a gateway laptop?
Fix A Gateway Laptop To Save Our Files From Getting Lost.
You can perform the following solutions to fix your laptop:
1) SYSTEM RESTORE
–>Restart your system and press F8 key.
–>You will be redirected to advanced boot menu.
–>Click safe mode with command prompt.
–>Type rstui.exe in the command window and press enter.
–>Select a restore point and click next.
–>Wait till the process is complete and then restart your desktop.
2) FACTORY RESET THE LAPTOP
–>Before the reset, back up all your essential data.
–>Restart the laptop and press Alt + F10 when the logo appears.
–>You will be redirected to recovery manager.
–>Click ’restore operating system to factory outlets’.
–>Wait till the restore process comes to an end.
–>Create your Windows account when prompted.
–>All your data vanishes and laptop behaves like a new purchased laptop.
