My birthday gift to my mom is an android phone and she really loves it. She is now 63 years old but despite her age, she’s still interested in using latest gadgets and mobile phones. The problem with the brand new unit I gave her is that, text and icon size are too small that she couldn’t easily see it. Can you shed some light as to how to fix HTC icon size change so we can set the desired font size and icon image size.
Fix htc icon size change
Hello.
There are several websites offering different kinds of applications in order to reset font size and text for htc mobile. These websites offer this kind of applications for free. I found a best application for you. Click on the below link to download this application.Â
http://www.handcent.com/dir/home
Thank you.
Hello Araceliariana,
You have not to worry at all. You can have your issue resolve by following any one of the following techniques discussed below
1.      You can use Google Playstore or Android Market to download third party applications which will change the GUI of your cell phone. One of the best is GO Launcher.
2.      You can also use Firmware update utility, which will update you to the latest android OS and might solve your problem.
3.      Goto Settings > Accessibility. You can configure the options according to the needs.Â
