Hello everyone, A few days back I purchase Lumia535. But now I have few battery issues. It doesn’t get charged even if I plugged in it for 2 hours. Kindly provide me the solution to fix Microsoft Lumia 535 battery problem.
If you just purchased the phone then probably chances are there that your battery is damaged. Visit your nearby service center if possible. Although you can try for the trouble shooting ideas like,
1. Let your phone first get discharged completely and then try to charge it.
2. When you start your phone, it will display the red battery logo kind of thing.
3. Turn on the airplane mode when it starts.
4. Don’t plug-off the charger until it gets charged till 100%.
5. Replace the battery if it stills not get charged.
If your phone doesn’t charge, make sure the outlet where you plug the charger has power. If your phone still doesn’t charge, there is probably a problem with the charger. To check it further, connect your phone to your computer using the USB cable. Check if your phone charges. If it doesn’t, transfer the USB cable to another port and try again.
Normally, when you connect your Smartphone to your computer using the USB cable, your device’s battery gets recharged. But if you don’t see any activity even on the battery meter, you can conclude that the problem is with the phone itself. In this case, you should bring it to a Microsoft service center for proper servicing.
The Microsoft Lumia 535 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on November 2014 and released on December 2014 measuring 140.2 x 72.4 x 8.8 millimeters and weighing 146 grams. It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 540 x 960 pixels screen resolution.
Microsoft Lumia 535
It supports multi-touch protected by Corning Gorilla Glass 3. It runs on Microsoft Windows 8.1 upgradable to Microsoft Windows 10 powered by Qualcomm Snapdragon 200 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 8 GB internal storage.
The primary camera supports 5 megapixels with f/2.4, 28mm, LED flash, and autofocus featuring 1/4″ sensor size and geo-tagging. It supports 480p video recording at 30 fps. The secondary camera supports 5 megapixels.
It supports 3.5-millimeter jack featuring Active noise cancellation with dedicated mic; Wi-Fi 802.11 b/g/n with DLNA and hotspot support; Bluetooth 4.0 with A2DP, LE, and aptX support; GPS with A-GPS and GLONASS support; FM radio; and microUSB 2.0. It has built-in accelerometer and proximity sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on removable BL-L4A Li-Ion 1905 mAh battery with standby time up to 552 hours and talk time up to 11 hours on 2G and 13 hours on 3G. It is available in white, black, orange, green, gray, and blue colors.
1....
