Hello everyone, I am having a problem after an update my phone. Every time I am trying to access my account it is saying “Can’t connect” message. Kindly help me out Microsoft Lumia 535 updates settings. Thanks in advance for the help.
Fix Microsoft Lumia 535 Updates Settings Related To Accounts.
1. If you are having this problem, at the starting you can skip it by hitting on Sign-in later.
2. Ensure that your phone is up to date. Go to settings then phone updates and choose check for updates.
3. Again navigate to settings, then choose email+account and select to add account and hit on Microsoft account.
4. If you have already registered then sign-in and proceed with it, it not then creates a new.
The problem may also occur due to a bad network connection, so please be sure that you are accessing a fast network and then sign in again if the problem occurs.
If you want to update your Microsoft Lumia 535 Smartphone, you need to connect your phone to the internet. If you have a Wi-Fi, connect your phone to your Wi-Fi network then try updating. Since your phone can’t connect to your Microsoft account, that means there is no internet connection. Connect your phone to your Wi-Fi and try again.
The Microsoft Lumia 535 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on November 2014 and released on December 2014 measuring 140.2 x 72.4 x 8.8 millimeters and weighing 146 grams. It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 540 x 960 pixels screen resolution.
Microsoft Lumia 535
It supports multi-touch protected by Corning Gorilla Glass 3. It runs on Microsoft Windows 8.1 upgradable to Microsoft Windows 10 powered by Qualcomm Snapdragon 200 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 8 GB internal storage.
The primary camera supports 5 megapixels with f/2.4, 28mm, LED flash, and autofocus featuring 1/4″ sensor size and geo-tagging and can record video in 480p at 30 fps. The secondary camera supports 5 megapixels.
It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic; Wi-Fi 802.11 b/g/n with DLNA and hotspot support; Bluetooth 4.0 with A2DP, LE, and aptX support; GPS with A-GPS and GLONASS support; FM radio; and microUSB 2.0. It has built-in accelerometer and proximity sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on removable BL-L4A Li-Ion 1905 mAh battery with standby time up to 552 hours and talk time up to 11 hours on 2G and 13 hours on 3G. It is available in white, black, orange, green, gray, and blue colors.
1....
