Fix Microsoft Office 2007 Error While Running
Hello, experts, I am having a problem while working on my Microsoft Office 2007 error while working. Kindly provide me troubleshooting tips to solve this.Thanks in advance for the help.
To solve the runtime problem of Microsoft Office problem tries the given below tips.
1. You can try to re-install the Office 2007.
2. You can try to stop the Windows Search Service. To do so follow the steps given below.
Click on start menu and in search programs and files, search for services.msc.
Right click on the Windows search and choose to stop.
3. Do a clean startup.
4. Ensure that all the updates are available and your system is up to date.
There are many errors that users may encounter when running programs and it would help if you indicate the kind of error you received. Anyway, if you encounter an error when running a particular Microsoft Office application, just try restarting it. Close the dialog or the error message and start that Office application again then see what happens.
Basically, if the error is just a glitch, the program will start normally again after a rerun. But if the error appears again, restart your computer and run that application again. If the error repeats over and over again, uninstall and reinstall it. Click “Start,” “Control Panel” then “Add or Remove Programs.” Scroll down and select Microsoft Office 2007 and click “Change.”
On the next screen, make sure “Add or Remove Features” is selected then click “Continue.” On the next screen, look for the application in error then set the dropdown next to it to “Not Available.” Click “Continue” to uninstall this program then restart the computer. After booting, open your web browser and go to CCleaner Free Download then download and install the free version.
Once installed, start CCleaner and clean your system. After this, repeat the steps above and go back to the Installation Options of Microsoft Office 2007. Now, set the dropdown of the program you uninstalled to “Run all from My Computer” to install all the program’s features on your computer then click “Continue.” Wait until it is complete then see if it works.
If you wish to convert CCleaner to Pro, download the codes and follow the instructions.
Notifications
