Fix Microsoft Office 2010 Error On Windows 7
Hello everyone, I am facing error 1704 while working on MS-Office. Kindly provide me a solution to fix Microsoft office 2010 error on Windows version 7. Thanks everyone for helping me.
To solve this error follow the following steps given below.
First, repair all the Registry entry related to the error. After this, full scan your system for any Malware on your PC.
Clean out the system for all the junks and make it junk free.
Ensure that your system is updated. Uninstall the software and then re-install it.
Run windows System file checker.
Install all the available updates and perform a clean installation of Windows.
Some users encounter error code 1704 when installing Microsoft Office 2010 but in your case it is different, you encounter it when running a particular Office 2010 application. Since the description of the error says “Microsoft Office has encountered a problem and needs to close,” try restarting the application then see what happens. If the error appears again, make sure Office 2010 is compatible with your computer.
I normally receive that message when running incompatible applications. Microsoft Office 2010 supports Windows XP Service Pack 3 (32-bit only), Windows Vista Service Pack 1, Windows 7, and Windows 8.x both 32-bit and 64-bit. Older versions of Microsoft Office like Office XP, Office 2003, and Office 2007 are not certified compatible with Windows 10 but they might work with or without compatibility mode.
The versions of Microsoft Office that are certified compatible with Windows 10 are Office 2010, Office 2013, and Office 2016. If you are using Office 2010 on Windows 10, there should be no problem. If you receive that error on a particular Office application, try to uninstall and reinstall that application. Also, try installing the latest Windows Update.
