Hello everyone, I got few Outlook 2013 error messages which cannot open Outlook window. It is happening with every Outlook file in my system. I cannot find a proper solution for it. Kindly suggest any applicable troubleshoot this problem.
If you have a problem with Microsoft Office Outlook and the email client completely doesn’t open, try to uninstall and reinstall it. If you have the entire Microsoft Office suite installed, you can disable this feature from the package. Click “Start”, “Control Panel” then set the view to “Small icons” on the upper right corner of the screen. Click “Programs and Features” then scroll down and select Microsoft Office.
Click “Change”. On the next screen, make sure “Add or Remove Features” is selected then click “Continue”. In “Installation Options”, click the down arrow for Microsoft Outlook then select “Not Available”. Click “Continue” then follow the instructions.
Disable Microsoft Office Outlook
When it is finished, click “OK” then restart the computer. After booting, repeat the same steps then in “Installation Options”, set Microsoft Outlook to “Run from My Computer”. See if this works.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
