Fix print command on the common vb control box
How do I fix the print command button on my common vb control box? Somebody set up this dialog box for
me and I didn’t know why the print button start to get an error message when I clicked it? Do you have any idea how to resolve this? I have no clue.
Answered By 5 points N/A #151783
Hello Cunningham Stevenson,
It will be better to give the exact solution if you give the error message string. There are several reason to give this error.
1. Any control that inside in the printing area, is not initialize.
2. Printer port can be blocked.
3. If you have the access to change the vb source code, then alternatively You can use the Vbprndlg.dll ( you can download this dll from Microsoft download center or follow this link) instead of the Print dialog box of the VB Common Dialog control.
Hope this would help
