s.walker
Posted on - 09/16/2016
Printer spooler is used to connect the Windows computer to the printer. The PC orders the printer to carry out tasks. If we get an error about the printer spooler we need to carry out methods to solve it.how to fix printer spooler?
Fix Printer Spoolerfor Proper Connection Of Computer And Printer.
1) CHANGE THE PROPERTIES OF SPOOLER
–>Press Windows key + R to open ‘Run’.
–>Enterservices.msc.
–>Double-click the printer spooler.
–>Go to general tab and stop the spooler and start it again.
–>Click on start-up and select automatic.
–>Press ‘apply’ to save the changes.
–>Go to the recovery tab.
–>Modify the settings.
–>At the end select apply.
2) SCAN SYSTEM FILES
–>Restart your PC.
–>Go to start menu and search control panel.
–>Right-click the control panel and press run as an administrator.
–>In command prompt, type ‘sfc/scannow’. This will start the scan.
–>If it prompts with a corrupt file continue with the process or else restart your computer.
–>You can solve the error on your own.
–>Replace the corrupt file with a new copy, by downloading it from the Internet.
