Fix Regsvr32 Error 0x80004005 On Your Windows
I am facing regsvr32 error 0x80004005 since the DLL Register Server call failed even after the reloading of the module. How to solve the error?
To fix the error on Windows 32-bit System follows these steps:
That problem is with a particular application you launched and not with the operating system. Since it is a DLL file error, make sure the program is compatible with your computer. Check the system specifications of the program and make sure your computer meets the requirements. In my experience, most of the DLL file errors I encountered deal with incompatible applications.
There are also ones that have only a missing component that missed installing. If the application you want to run requires other programs, make sure those programs are already installed before using your application. Next time before you install a program, ensure the system requirements are checked and followed.
Notifications
