Fix Software Update Error IPhone 8
My iPhone is showing error 9 message in iTunes.How do I fix this software update error iPhone 8? When does this error occur?
The error 9, 4005, 4013 or 4014 occurs when you update or restore your iPhone, the error message might pop up when you choose your iTunes. If your device disconnects during an update or restoring process or if iTunes couldn’t tell your device to restore, these error messages can be seen on the screen. To fix it,
1. Try installing the latest version of iTunes.
2. Force your device to restart
3. Try restoring the device using your computer via a USB cable
4. If the error persists, contact your nearest iPhone service center
That is not an error 9. The dialog is showing “iOS 9” and not “error 9.” It seems the problem here is because of the iOS version you are downloading for your iPhone. The Apple iPhone 8 Smartphone ships with iOS 11 and the one you are downloading is iOS 9 which is not compatible with your device.
iOS 9 supports iPhone 4S, iPhone 5, iPhone 5C, iPhone 5S, iPhone 6, iPhone 6 Plus, iPhone 6S, iPhone 6S Plus, and iPhone SE. Here are the specifications of your phone. The Apple iPhone 8 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public and released on September 2017.
It measures 138.4 x 67.3 x 7.3 millimeters and weighs 148 grams. It uses nano-SIM card. It is IP67 certified which is dust and water resistant up to 1 meter for 30 minutes. It supports Apple Pay (Visa, MasterCard, and AMEX certified). It has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 750 x 1334 pixels screen resolution.
It supports multi-touch protected by Ion-strengthened glass with oleophobic coating with wide color gamut display, 3D Touch display & home button, and True-tone display. It runs on iOS 11 upgradable to iOS 11.2 powered by Apple A11 Bionic chipset, Hexa-core (2x Monsoon + 4x Mistral) processor, and Apple GPU (three-core graphics). microSD is not supported.
It runs on 2 GB RAM with either 64 GB or 256 GB internal storage. The primary camera supports 12 megapixels with f/1.8, 28mm, phase detection autofocus, OIS, and quad-LED dual-tone flash featuring geo-tagging, HDR (photo/panorama), touch focus, simultaneous 4K video and 8MP image recording, and face and smile detection.
It supports 2160p video recording at 24 fps, 30 fps, and 60 fps and 1080p at 30 fps, 60 fps, 120 fps, and 240 fps. The secondary camera supports 7 megapixels with f/2.2 and supports 1080p video recording at 30 fps and 720p at 240 fps with face detection, HDR, and panorama. It doesn’t support 3.5-millimeter jack.
It has Wi-Fi 802.11 a/b/g/n/ac with dual-band and hotspot support; Bluetooth 5.0 with A2DP and LE support; GPS with A-GPS, GLONASS, GALILEO, and QZSS support; NFC (Apple Pay only); and USB 2.0 proprietary reversible connector. It doesn’t have FM radio. It has built-in front-mounted fingerprint, accelerometer, gyro, proximity, compass, and barometer sensors. The pre-installed web browser supports HTML5 (Safari). Java is not supported.
It runs on non-removable 6.96 Wh Li-Ion 1821 mAh battery with talk time up to 14 hours on 3G. It is available in silver, gold, and space gray colors.
Notifications
