Fix up virus problem without formatting.
Dear Jakie,
The problem you’re facing is virus. It’s a big problem to most of the computer users. I know I have also faced this type of problem.
Sometimes it gets really tough to find out which one is the best solution for our computers to keep them protected from virus. Well I’m suggesting you some possible solutions to keep computer free from virus.
As you said you don’t want to format “C Drive” or give a setup then the best solution is to uninstall all unnecessary software’s that are installed in your computer. For that go to:
Start > Control Panel > Add or remove software. Uninstall all unnecessary or heavy size soft wares.
Make sure the software is deleted from your “C Drive” or you can delete the file from the program file manually.
Use “C Cleaner” Software for your System drive or “C drive”.
I would like to suggest to uninstall the McAfee Antivirus and use the best Antivirus software to keep your computer protected against virus threats. I know you may face difficulties regarding choosing the best Antivirus software. Well I’m giving you the features of some of the best Antivirus software.
At present the ranking of 3 best Antivirus software goes like this:
BitDefender Antivirus Pro 2011
Kaspersky Anti-Virus 2011
Webroot AntiVirus 2011
I would like to suggest you to use BitDefender Antivirus Pro 2011 for your PC security solution
Well at present BitDefender Antivirus Pro 2011 and Kaspersky Antivirus 2011 are the most trustworthy Antivirus on net and they are fighting a lot for your attention.
BitDefender Antivirus Pro 2011 Fractures and Protection process:
Kaspersky Antivirus 2011 Fractures and Protection process:
WebRoot Antivirus 2011 Fractures and Protection process:
Try to give a Windows Setup frequently. And after setup without giving the computer internet connection create a restore point for your computer. It would keep a “Restore Date” and will help you to get back to the position after the setup of the computer.
For that go to Programs > System Restore, to make a restore point.
Try not to visit those sites that cause virus to attack your computer and enable the “LINK FILTER” in your Antivirus software. (Most of the software provides this service). The Link Filter will help you to detect which site is GOOD Ranking and which one is BAD ranking. So it would be helpful for you.
Try to format each of your drive. I know it’s really tough since many important documents of yours are kept inside the drive. So I would suggest you take them to a portable drive or pen drive then format the drive and after that bring back your files from pen drive or portable drive after scanning them.
Some basic tips are given below:
Hope my suggestions will help you solving problem.
Thank you.
My advice is, use Norton Antivirus for full scan performance.
