Fix VMware Workstation Failed To Connect To The Workstation Server. Help Me.
On my system I am having the problem VMware workstation failed to connect to the workstation server. What can I do to resolve this issue? Please help!
If you are unable to connect the server then make sure your VMware is working proper.
Make sure your virtual machine is updated to latest version.
Start a command prompt on your host system; It should be Administrator account and type the command.
C: \program files\VMware\workstation\vnetlib.exe – –
Install hcmon
Now check the Service console of your Windows machine and start it manually.
If the problem is not solved then, uninstall the application and install it back.
Thank you!
Notifications
