Fix Wab32 Dll Missing
I am trying to publish data in Outlook. However, an error message WAB.dll is missing. What can I do?
If Wab32.dll is on your laptop, rename it and paste it categorically into Outlook. Rename Wab32.dll Click “Start,” “Destination,” then click “Files or Folders.” Type Wab32.dll in the Name box, and then click Perform. With the appropriate button, click Wab32.dll, and then click Rename on the Route menu. Type Wab32.old and press Enter. You can replace the corrupted or missing Wab32.dll file by running the Windows 98 Setup program. To edit the file, follow these steps:
Click Start, select Settings, and then click Dashboard. Double-click the software icon. Click the Windows Setup tab. In Rooms, click to clear the check mark next to Microsoft Outlook, and then click Apply. Once the Outlook category is removed, add the marker to the Outlook category and click Apply again. This can be categorically defined in Outlook. The Wab32.dll file is replaced by a replacement copy.
Notifications
