Fix Windows Live Mail Error Id 0x801941f7
When I upgraded to the new outlook, I got an error message with error ID 0x801941f7. The application just stopped synchronizing with emails, calendar events, and contacts and I am unable to use the email with Windows Live Mail 2012. Can someone help me fix this problem?
Answered By 0 points N/A #318991
Since June 2016, Microsoft Outlook incorporated a new feature with which Windows Live Mail does not work. So, no solution to this problem exists, and so you have to find alternatives.
Try one of the alternatives listed below:
1. You can use Outlook as your mail client.
2. Use the in-built Mail app for windows. For this go to Windows > Type Mail and select the result. Then click the Settings button(bottom gear icon)>Manage Accounts > Change mailbox sync settings. Now you can synchronize and restore everything from your previous Window Live Mail 2012.
3. Otherwise, use Outlook 2016.
