Fix The Windows Logon Process Unexpectedly Terminated Error
I am getting error messages on my Windows Operating System that the Windows logon process has unexpectedly terminated. I have also checked that the System resources are adequate. How can I fix this problem?
Answered By 0 points N/A #166379
Since you have already checked the System resources, the cause for this fault possibly is that the Windows registry is corrupted. You can still login by running a Recovery Console or in Safe Mode. If the registry is corrupt, you have to restore the computer to an earlier saved time. The other cause may be that a particular service failed to start. Check and determine the error code and restart the service by running services.msc and starting that particular service.
