Fix Your Samsung 6e Error Code With A Few Simple Steps
Hi, I am using Samsung water heater and I am getting some Samsung 6e error code that I can’t figure out. What should I do? Please reply ASAP. Thanks in advance.
To fix the problem, you need to follow few simple steps. You’ll find that the heater isn’t getting hot and element is not showing faulty, so the 6E fault in seen in the control panel.
There is no short term cure for this problem, the cabinet needs to be dismantled and then you be able to gain access to the heating element. You would probably have to replace the faulty element. This kind of fault suggests that to the element the controller has sent power, but hasn’t at all heated the machine (as shown in the thermostat). This is how you might come to know about your problem, and then act accordingly to fix it.
If your problem keeps persisting, contact Samsung support wing.
Notifications
