Fix Youtube Error 500 Internal Server Error Possibility.
I have been getting this one error called youtube error 500 internet server error. How do I fix this? Reply ASAP.
The “500 Internal Server Error” you see when visiting YouTube is a general HTTP status code. This error indicates something is wrong with the website’s server but the server can’t point out the exact cause of the problem. There’s nothing much you can do about it because the problem is with the website.
But there are things you can do that can help verify if the problem is in your end. When you encounter this error on a website, the first thing you should do is to refresh the page. Press F5 on your keyboard to reload the page. If this doesn’t work, try clearing the browser’s cache. This will delete your browsing history.
If this doesn’t work either, try deleting cookies. Press CTRL + SHIFT + DELETE on your keyboard to bring up the “Clear browsing data” dialog then check the option to delete cookies and then click “OK”. Deleting browser cookies will logout any logged in accounts.
