Louise Rios
10 points
Posted on - 07/14/2017
I have been trying to install framework 1.1 for Windows 7 on my PC for some work but it is continuously giving an error saying that application has generated an exception. Please help me fix this.
Fixed Framework 1.1 For Windows 7 Installation Error
To fix the error-
- Create a new folder named dotnet in c drive and save the setup file there as dotnetfx.exe
- From the given link download the package and rename it as dotnetfxsp1.exe
http://www.microsoft.com/en-us/download/details.aspx?id=33
- Copy the files into the folder you created and then open command prompt
- Go to dotnetand then enter the command
dotnetfx.exe /c:”msiexec.exe /a netfx.msi TARGETDIR=C:\DotNet
- Then run the following commands
dotnetfxsp1.exe /Xp:C:\DotNet\netfxsp.msp
msiexec.exe /a c:\DotNet\netfx.msi /p c:\DotNet\netfxsp.msp
Then install framework 1.1 by running netfx.msi from the working folder
That’s right. Microsoft .NET Framework 1.1 is a very old Windows component package to be installed on Microsoft Windows 7 and it is not designed to work on Windows 7 and higher operating system. You can install Microsoft .NET Framework 1.1 on Windows 2000, Windows XP, Windows Vista, Windows Server 2003, and Windows Server 2008.
If you want to install a version of .NET Framework on your computer, the lowest possible version that will work on Windows 7 is Microsoft .NET Framework 4. The version before this, Microsoft .NET Framework 3.5 Service Pack 1, is designed to run on Windows XP, Windows Vista, Windows Server 2003, and Windows Server 2008. This, too, is not compatible with your operating system.
