Fixes For Autocad Cannot Continue Error
I am trying to open a file in AutoCAD 2010 but I have been getting the persistent error AutoCAD cannot continue. Can someone tell me troubleshooting steps relevant to this problem?
Answered By 0 points N/A #289695
Solution-1
To resolve this issue visit this link
You can try changing the ISAVEPERCENT value. This works in most cases. To change the value, just type ISAVEPERCENT in the command box and hit enter.
Solution-2
Increasing the virtual memory also helps and you can try this if the first solution doesn’t work.
