Fixes For Chrome 64 Bit For Windows 7 Blank Page Error
I am looking for fixes to chrome 64 bit for Windows 7 blank page at startup error. It doesn’t miss the default website at startup. Guys please help me with this.
To fix the problem you are having-
This will solve the error.
If that is what’s happening when starting Google Chrome, try to clean install the browser. Go to Revo Uninstaller Freeware and download the free version. Once installed, run Revo Uninstaller, select Google Chrome from the list, and click “Uninstall.” Follow the instructions to remove the browser. This will remove everything the program created on your computer.
After the normal uninstall, click “Scan” to allow Revo Uninstaller to scan your computer for any leftovers. After the scan, click “Select all” then “Delete” to delete all items found. When all leftovers are deleted, exit Revo Uninstaller and restart the computer. After booting, go to CCleaner Free Download and download the free version. Once installed, start CCleaner and clean your system.
After this, go to the Google Chrome home page and download the latest. Once downloaded, run the installer to install the latest Google Chrome. See if this fixes the problem. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
