Fixes For Microsoft Office Error Code 0x8007232b Error
amber ward 10 points N/APosted on - 07/06/2017
It’s been a year since I am using my PC with office 2010. But from last week I am getting the error saying Microsoft office error code 0x8007232b. I was not getting this activation error before. Please help me fix this.
The only cause behind this error is that you are entering the wrong product key or combination. Try checking it again and entering it.
Or else you can try entering this MAK Key:-2PWHY-KT4X6-96PYW-XQR7V-HW2W9 by going to file and then help in Microsoft office 2010. There you need to enter the above key. Then restart all the office applications.
Error code “0x8007232b” is an activation error which you may receive when activating the operating system like Windows Vista, Windows 7, Windows 8.x, Windows 10, Windows Server 2012, and Windows Server 2012 R2. Since it has something to do with activating Microsoft Windows, make sure your computer’s date and time settings including the time zone are correct.
Click “Start,” “Control Panel,” “Date, Time, Language, and Regional Options,” and then “Date and Time.” Select “Time Zone” tab and select your correct time zone from the dropdown list.
Setting the correct time zone
Next, select “Internet Time” tab and make sure “Automatically synchronize with an Internet time server” is checked. In “Server,” select an internet time server from the dropdown list. You can select between “time.nist.gov” and “time.windows.com.”
Select an internet time server
In my computer, “time.windows.com” doesn’t work so I use “time.nist.gov” instead. When you’re all set, click “OK” then restart the computer. Try activating Windows again and see if it works. If the problem continues, visit Error 0x8007232b or 0x8007007B Occurs.
1....
