Fixes For Microsoft Security Essentials Error Code 0x80070643 Error
After doing a repair install of windows on my PC, I am getting a message saying MSE was turned off. I have already tried restarting the device and doing re installs, but now I am getting a Microsoft security essentials error code 0x80070643. Can someone please help me with this?
Answered By 10 points N/A #300430
This problem arises mostly when you are missing some update of Microsoft security essentials. You need to make sure that you have all the required updates.
Visit this link for the required updates.
Or you can try checking this link for other troubleshooting steps, it the one above doesn’t work.
Answered By 590495 points N/A #302379
You may receive error code “0x80070643” when you try to install Microsoft Security Essentials, Windows Live Essentials, or a specific Windows Live application such as Windows Live Messenger. The problem happens because the previous installation or the old installation puts the computer in a state where there is a pending restart. To fix the problem, try restarting the computer then reinstall Microsoft Security Essentials.
When reinstalling, don’t uninstall the existing version. Just run the installer of Microsoft Security Essentials to install over the existing installation. On the other hand, if you receive this error when installing Microsoft Security Essentials, download and run Microsoft Security Essentials Removal Tool to remove any leftover files from your computer.
Once uninstalled, restart your computer and install Microsoft Security Essentials again.
