Fixes For Windows Fatal System Error Listed
I need fixes for Windows fatal system error as it is repeatedly popping up and many processes are crashing. Please help me with this problem as it is becoming a hindrance. Thank you.
To fix the fatal system error-
One of the methods will fix the error
That’s kind of unusual because you normally get fatal errors on programs or applications but not with the operating system itself or Microsoft Windows. If you frequently receive fatal errors in Microsoft Windows even if you are not doing anything, try running the System File Checker tool. Click “Start,” “All Programs,” “Accessories” then right-click “Command Prompt” and select “Run as administrator.”
In the command prompt window, type without quotes “sfc /scannow” then hit Enter. Wait until the process is complete. If you are prompted to insert the Windows setup CD, insert your Windows setup CD on your optical drive and continue. When it is finished, restart the computer and see if it works.
