Fixing 0x000006b Error
How to fix the STOP 0x000006b error. According to the Microsoft Knowledge Base, this is done using the bootcache.cat file. What is this bootcache.cat file?
The STOP 0x6B error causes the Microsoft Windows package to fail at a low level. The STOP 0x0000006B code can also indicate “PROCESS1_INITIALIZATION_FAILED” in the STOP constant message. I guess you buy a BSOD. This is often caused by problems with boot hardware, memory, or card loss. Make sure your hardware is properly installed and that you have selected the correct memory for the server. Are you intimidating Windows 7 instead of servers? You can try manually removing bootcache.cat from \ Windows \ system32 \ CodeIntegrity. Then revive the computer. Otherwise, insert a Windows DVD and use the restore options “Restore” and at least once to delete the file.
