Sara Carter
10 points
Posted on - 07/18/2019
I loaded the Idiom Worldserver desktop workbench, but I continue to receive error messages. The prompt says cordbg exe JIT debugger error. An attempt to start a JIT computer program with the following command resulted in a voucher code of 0x2 (2). Please check the PC settings. Cordbg.exe! a 0x238 I uninstalled and reinstalled Microsoft .NET Framework one.1 Service Pack 1 as requested for the package. It is indicated to run with various infrastructure service packs, but it still displays a constant error message.
Fixing Cordbg Exe Jit Debugger Error
I recommend that you change the enabled or disabled Windows options in the .NET Framework, disable them, and see if this can help. Here, you measure the square steps. Click the Start button, click Dashboard, click Programs, and then click Turn Windows Options On or Off. If you are asked to confirm a conditional release or confirmation as a partner in the Nursing Administrator, sort the parole or offer a confirmation.
- Disable .Net Framework and click OK.
- Restart the PC, follow a similar procedure and check the .Net Framework.
OR
Try to run the SFC analysis of the performing arts on your PC.
SFC / scannow could be a very useful command that you can use in any version of Windows. Once the SFC (System File Checker) command is used with the / scannow switch, the tool can scan and replace the required Windows files on your laptop.
Missing and corrupted software files (such as multiple DLL files) are undoubtedly the main reason for major Windows problems. Given this and the fact that SFC / Scannow is completely automatic and extremely easy to use, the tool should normally be one of your first steps in troubleshooting.
