Hi!
I am just new to this software. I am just trying to explore everything about it. Can you give me what are the benefits of using it? What are the system requirements in installing this to a laptop? Can you give me what are the benefits of this software? What are the capabilities and other features included with it? Can you tell me what are the common issues that can happen while using it? What are the resolution of the pictures that I can use to enhance the brightness?
Fixing A Dark Or Light Picture Picasa editing software
Picasa is a good software for editing images. It is user friendly and it is easy to get use to editing images.
Benefits of using Picasa is it helps you edit photos in many different ways you want like you can change the resolution, you can crop, you can add a text, you can change the images color, you can change the brightness, you can merge 2 of moreimages into 1 image, etc.
You can find all the images on your computer in folder design in picasa so that all the images can be found at one place. So making it easier to find a particular image.
It is good to use picasa synchronized with gmail or google+ though you should have a good privacy settings or else when you upload edited pictures online it might be open to public so before uploading make sure you keep privacy settings as you need.
You can all sort of resolution there had been no problems known for now with any resolution.
From picasa it is easy to edit and share photos.
You can even add tag to keep your images organized.
