Fixing Epson 0xf4 Error
I was trying to print something when my printer stopped working and started showing error 0xf4. I don’t know what this means. What can I do to make my printer working again?
The reason behind this error can be jammed paper, unavailability of ink or maybe broken components. You can fix this using Reimage Repair Software. First of all, you have to download Reimage Repair Software from a trusted link, and you can also save it on the desktop for easy access.
Double-clicking on the file will start the installation. After installation, a welcome screen will be displayed. Un-tick the checkbox which will be ticked by default. This will enable the tool to carry on the further process automatically. The tool will detect and describe the problem. Now restart the computer and the process is complete.
If you are about to print something then your printer suddenly shows the “0xf4” error, try this. Click “Start”, “Control Panel” then set view to “Small icons” and then click “Device Manager”. Next, locate your printer, right-click it then select “Uninstall”. If your printer is not listed, make sure the printer is plugged in to the power and turned on and connected to your computer via USB cable.
After this, disconnect the printer from your computer then restart the computer. After booting, connect the printer back to your computer using the USB cable. This will then install the device again. Try printing again then see if it works. If the problem continues, download the free version of Revo Uninstaller and install it.
Once installed, start Revo Uninstaller then select your printer software among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo Uninstaller then download your printer software from the manufacturer’s website.
