I had this inconvenience right now for a moment. I usually have Windows 8, and then an upgrade to version 8.1, as the general public did with desktop computers. After a few months of the release of version 8.1, the updates failed for no apparent reason. I searched on Google for the four updates that could not be installed (I do not remember what they were doing, but it was the four who made the update as soon as you could book Windows 10 so I could not reserve a copy) and there were no corrections. I had a link to inserting Windows 10 last night in the hope that it corrects my disadvantage, which is unfortunately not the case. I am currently unable to perform updates: KB3081424, KB3074678, and KB3074678. I have not found patches online for Windows 10 yet.
I do not know if it’s often something to try, but it will not allow me to install applications from the store, thanks to the error 0x80070002. Please help me fix this!
Fixing Error 0x80071a91
We will perform the steps manually. Resetting Windows Update items can repair damaged Windows Update items. Follow Coordinate with the told instructions:
1. Open cmd as an admin.
2. Quit the installers for BITS, Cryptological, MSI, and Windows Update Services. Enter the following commands in Associate in Nursing transmission. Press Enter once you have entered each order.
wuauserv web stop
Internet Stop cryptSvc
Internet-stop bits
Internet stop msiserver
3. Rename the folder SoftwareDistribution and thus the folder Catroot2. You do this by calling the subsequent commands within the transfer. Press Enter once you have entered each order.
ren C: \ Windows \ SoftwareDistribution SoftwareDistribution.old
ren C: \ Windows \ System32 \ catroot2 Catroot2.old
4. Restart the BITS, cryptographic, and MSI installation programs, as well as Windows Update Services. sort the following commands in the electronic communication. Press
Enter when you sort each order.
Internet begins wuauserv
Internet starts cryptSvc
Internet start bits
Internet start msiserver
5. Sort Quit in the electronic communication to close it. Restart the PC.
6. After restarting the PC, try installing Windows updates.
