Fixing Error 0x8008005
Can anyone help the US state with this inconvenience because I can not use the Windows update program because of the Windows update error 0x8008005 as declared in Windows Update Diagnostic and 0X80080005 in the Windows update program?
Answered By 0 points N/A #322254
Resolve this error:
Quickly press the Windows and R key.
Enter Firewall.cpl and click OK.
Select Enable or disable Windows Firewall.
In the private network settings, click Stop Windows Firewall (not recommended).
Follow the same steps to configure the public network. OK click.
The next step is to scan your system for corrupt or missing system files:
Enter CMD. OK click.
At the command prompt, copy “sfc / scannow” and paste it.
We want Associate to run the command in Nursing Administrator Access. Right-click CMD and select “Run as administrator”.
