Fixing Error 1935 Crystal Reports Installation Windows 7
Asked By 5 points N/A Posted on -
I receive the error message 1935 – An error occurred while installing the assembly assembly assembly. The laptop should have 32 bits of Windows.
I downloaded CRRuntime_32bit_13_0.msi from the indicated link and tried to install it on my laptop. Is there a new update? Is it a legendary subject? Please give me the fix for this error 1935 crystal reports installation Windows 7!
Answered By 50 points N/A #322662
Uninstall everything I thought and get .NET Framework 4.6.1 (Visual Studio 2010 and all its dependencies, as well as SQL knowledge tools, etc.).
Uninstall the .NET Framework (this will reset the system to version 2.0 by default in the case of Windows 7, I think)
Uninstall all Visual C ++ runtime environments.
If necessary, uninstall all Crystal Reports executions.
To restart
Install the Crystal Reports (x86, x64) executions.
Reinstall the .NET Framework Four.6.1
Reinstall the Visual C ++ runtimes.
Fortunately, I did not want VS2010, I had similar settings in 2015.
Everything works now!
