Fixing Error 80071a90 Vista
I get this error 80071a90 vista when I try to insert a scene update at resuscitation says “Configure updates and not configure updates successfully”I was really looking for this error code and did not notice it. Communities can you activate it?
Answered By 0 points N/A #321582
To solve this error you either go for troubleshooting or download an update manually rather than allowing Windows to do it. Troubleshooting will make things easier and you don’t have to follow many steps. I suggest you go for trouble shooting as it always works. But if incase it doesn’t fix your issue then you should download the update yourself and uninstall the one performed by windows.
