Fixing Error Code 0xc004f063 Windows 7
I have the key Windows 7, I typed and activated, and so far everything was fine as soon as it was reported that my copy was not authentic. I have tried repeatedly to enter the code and it continues to give the US federal state the error code mentioned above: error code 0xC004F063 windows 7. Please, facilitate validation!
Answered By 0 points N/A #322302
Step 1: If you manage to start frequently, try uninstalling and reinstalling the property key and see if it helps you.
a. Click “Start” and sort “cmd” (without quotation marks) in the “Start” search box.
b. In the list of programs, right-click on cmd and select “Run as administrator”.
c. In the command shell, sort the following command and press Enter for each command.
slmgr -upk
slmgr -ipk (your product key)
d. Activate the copy again and see if it works.
Step 2: You will first try to activate online if phone activation is not redone, as you have already tried.
Step 3: You are making an online effort to significantly improve Windows and check if you are correcting the problem. Visit the official website of the name listed below and click “Validate Windows”.
Genuine Microsoft software.
Problem solved!
