Fixing with load dds civilization 5
Hello All, When I load dds civilization 5, there is an error occurring with icon. It seems that there are some files missing. Can everyone can help on this? Thanks
In order to solve this problem you to reset up the dds civilization 5. If you face problem now you have to download missing files from the net and set up it. In this way your problem will be solved.
Sometime it happened for flash player; you can also update your flash player.
Dear Jett Phoenixx,
It is better to reinstall it. In many situations, the main problem arises due to mistakes which occurred during installation.
Many games have this problem, but it can be fixed easily after reinstalling.
If that doesn’t work for you, try the recommendation discussed in the following site:
http://steamcommunity.com/discussions/
Under (Slimewowgrogga) suggestions, you will find very helpful steps to fix such a problem.
Best regard,
Don Muench
