Fixing Msvcr100.dll Error Windows 7 System
My system is showing msvcr100.dll is missing, what is the solution to msvcr100.dll error Windows 7 system? Why does this error occur?
The Msvcr.dll is a Microsoft Visual C++ Redistributable file that is needed to run files built with Visual Studio 2011. The error occurs when you try to run software that requires Microsoft Visual C++ redistributable and is not found. This error is mainly caused by human error or virus, hardware failure or malware. The software can be found on the Microsoft website for both the 32 bit and 64 bit and install it will fix this issue. Another way of solving this issue is by using recovery software to recover the deleted DLL file.
The “msvcr100.dll” file is part of Microsoft Visual C++ which is required to execute programs that were developed using Visual C++. Some games or applications that require it includes the file in its installation. If for some reason, you receive an error related to this DLL file like it is missing or cannot be found, try reinstalling the program that triggered the error.
Reinstalling the application will also restore the missing or corrupt DLL file. If this doesn’t fix the problem, try downloading Microsoft Visual C++ 2010 Redistributable Service Pack 1 and install it. See if this fixes the problem.
