Fixing NINTENDO ERROR CODE 51330 On Wii Console
I have been seeing a NINTENDO ERROR CODE 51330; I have lost connection with internet, and I am not able to get it work. Can you please help me?
When this problem occurs, the connection to the internet is not possible. This gives us an indication that the there is an authentication problem. This is not a serious issue. It is quiet common. This mainly happens when the router with holds the connection because of incorrect security password.
This is simple to solve the problem. There are some procedures to solve this issue. To start with, first thing is to remove the power cables from the wireless router and modem. If there is, any back-up battery installed then disconnect it. Wait for a minute or two then install the cables to the modem and wait until it gets steady. Then install the cables of the router and wait until it gets steady.
This solution is applicable for many consoles. Some of them are Nintendo Ds lite, Nintendo DSi, Nintendo DS, Nintendo DSi XL, Nintendo DS Lite, Nintendo 2DS, Nintendo 3DS XL, Nintendo 3DS,Wii, New Nintendo 3DS XL, New Nintendo 3DS, Wii U Deluxe, Nintendo switch, Wii U Basic, etc.
Notifications
