As long as I activate my laptop. It’s as if things were in order. Then I buy the black screen again to put it in safe mode. I try this so that the blue screen reappears. I want to understand what I should try. I have tried all modes, but nothing seems to work. How can I solve this error ox0000007e?
Fixing Ox0000007e
Problem solved! Well, I have a constant error code:
the blue screen error * STOP OX0000007E (OXCOOOOOO5, OXF86378B9, OXF6ACEE60, OXF8ACEB5C.
The solution is simply to install additional RAM. It works 100%.
Fixing Ox0000007e
For “0x0000007E” Stop error, the full error reads:
“Stop 0x0000007E (parameter1, parameter2, parameter3, parameter4)
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED”
Users with Windows 7 or Windows Server 2008 R2 may encounter this error and the operating system may crash intermittently. Note: the parameters in the Stop error message vary depending on the configuration of the computer and not all “0x0000007E” Stop errors are caused by the same problem.
This error happens because of a race condition triggered when a NULL lease handle is accessed after the lease spinlock is released. To fix the problem, a supposed hotfix can be downloaded from the Microsoft website but unfortunately, at the moment, this hotfix is no longer available. Instead, Microsoft recommends that you install the latest update for your operating system or upgrade your platform to Microsoft Windows 10.
Try updating your operating system to the latest Service Pack. For Windows XP, download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP. For Windows Vista, download Windows Vista Service Pack 2. This is the latest and last Service Pack update for Microsoft Windows Vista. For Windows 7, download Windows 7 Service Pack 1.
This is the latest and only Service Pack update for Microsoft Windows 7. For Windows 8, update to Windows 8.1 from the Windows Store.
