I received the error message “The program can not run because Qt5WinExtras.dll crashed” when I launch the sport and even the launcher is not displayed. Yesterday, I do well the competition but since this morning, this error is displayed again and again. I’m competing with this sport before it’s completely unloaded and I’ve never had that problem. If someone presents a solution or plan that is not right, I will appreciate the help.
Fixing Qt5winextras Dll
With WikiDll Fixer you can automatically fix qt5winextras.dll error. The utility not only downloads the correct version of qt5winextras.dll for free and suggests the appropriate installation directory, but also fixes other issues related to the qt5winextras.dll file.
Go for “Download Solution” button and Install the utility by following the simple installation instructions. Start the program to resolve qt5winextras.dll errors and other problems.
The “Qt5WinExtras.dll” file could be related to QuickTime. First, if you keep getting this error, check the system requirements and verify that your computer meets those requirements. If this is not the problem, try to uninstall and reinstall the program. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select the affected program among the applications and click “Uninstall.”
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install the program back. If you haven’t updated yet, download the latest version to update.
Also, since the file is related to QuickTime, try downloading QuickTime 7.7.9 for Windows. The latest QuickTime at the moment is QuickTime X but it is now exclusive for OS X. Apple stopped supporting Microsoft Windows in 2016 so that means QuickTime 7.7.9 is the latest and last version to support the Microsoft Windows operating system.
QuickTime X is currently available on OS X 10.6 Snow Leopard and higher and is part of the operating system. To open QuickTime X on Mac, go to your “Applications” folder and open QuickTime. You may also see QuickTime Player 7 there but it is a different program. Apple doesn’t provide a separate download for QuickTime X.
