Fixing The Error Of Gds32 Dll Download
I have an FDB (Firebird) file from a new buyer (he does not understand the version). In fact, I tried to use a graphical interface to access the information, but without success. All say that its gds32.dll is missing, but I did it. I derived this DLL in the GUI folder, I actually derived the DLL in the System32 folder and I derived it in syswow64.
I am using Windows 7 64 bit and Firebird information is also 32 bit. I actually tried to put in the DLL, but I can not save it. I checked WinXP in a very virtual machine to see if it worked no result. I tried IbExpert Personal, Ibmanager and Flamerobin and found that there was an equivalent error that the DLL was not found or entered. How do you open this firebird database?
Answered By 10 points N/A #323053
You need a running Firebird server to access your information. If you just want to access the information, the easiest way is: Get the free FDBConvert utility and update the information to the Firebird 5 format Install a pair of servers on Firebird. Here you can install. Use the Win32 version if your GUI tool is a 32-bit application. During the installation, check the “Generate purchase library as GDS32DLL to support gift applications?” Check box. Make sure the Firebird service is running and verify that the information is attached.
If you want to access information via an associate degree from a previous application, you must do the following: Determine the required version of Firebird. Use the command gstat -h basename.fdb. Check the version of ODS. In the table below, you can see a correspondence between the ODS variant and the Firebird version. The gstat utility can be part of the server installation. Download and install an acceptable version of the Firebird server.
