milodiaz
10 points
Posted on - 06/10/2017
Hello. I recently installed an application. On running it I found the msvcp100.dll Missing Error. How do I check these errors? What should I do to make sure this is prevented? Please reply as soon as possible.
Fixing The Msvcp100.dll Missing Error Or Not Found:
Hey. Your error is fairly common. The error occurs when the msvcp file may be inadvertently deleted by the user. The error can also be a malware issue or a registry issue.
1) You can fix this by downloading the missing file from a DLL website.
2) It is better to download the Microsoft Visual C++ 2010 service pack. Run the file and this will help replace and if not already present get you the specified DLL file.
3) You can install the recent Windows Update and try to correct the error.
4) Check recycle bin to see if the DLL file is present. If present restores it.
If a particular DLL file is missing after installing an application, try to uninstall and reinstall the program. It can be the result of an incomplete or corrupt installation. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your program among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install the program back. See if this works. If this doesn’t work and the DLL file is still missing after reinstalling it, just download the missing DLL file.
Download msvcp100.dll and unpack the ZIP file with WinZip, WinRAR, or 7-Zip. Once unpacked, copy “msvcp100.dll” to the installation folder of the program needing it. After this, start the program then see if it works. If this doesn’t work, copy the DLL file to “C:\WINDOWS\system32” then see if it works.
