Zac Winnie
Posted on - 05/26/2020
I am trying to download pinnacle studio for windows 7. However, the process is getting stalled and the following error message is being flashed.
What should I do to complete the process without fail?
Fixing the stalling of the download of pinnacle studio for windows 7
Hey! You are probably getting this error due to poor connectivity. Ensure that your internet connection is uninterrupted. You would probably have to reset your router and modem. Preferably, switch to a wired connection if you are not already using one.
In spite of doing this, if you repeatedly get this error, try restarting your computer as well as the download. Try using a different browser from the one you are using. In case the problem persists, download the file by the Manual method instead of the Download Manager.
