Antonne
Posted on - 11/07/2011
Your help and support please for a problem with the Windows7 program! I installed a program namely Windows7 in my personal computer. I have external drives like CD and DVD, but iNi Windows7 is always trying to burn and write files to removable media. I would like to stop iNi which keeps on creating something in my Desktop. Another question I have is how will I fix the entire Windows7 setting? Thanks in advance!
Fixing Windows7 setting; problem with iNi
Hi Antonne
I think you have iNi Windows 7 set to load at startup. Disable the option of launch at start in the program's settings. Or you can click on start and then click on Run. Type msconfig and press enter, navigate to the startup tab. Here locate the iNi Windows 7 and click on it so that the check box is not ticked. After you apply the changes it will ask for you to restart.
To change the entire windows settings all in one go you got to create a new user account. This you can do in the account settings in the control panel. Otherwise you have change each individual settings one by one.
Hallo Antonne,
It seems that your computer has the problem with the drivers, either they are corrupt or they did not install properly. Some important system files called the .ini files may be missing and therefore you have to rectify that.
I will suggest that you get a program called ccleaner and install it on your computer. Launch it and then choose the option for fixing registry files.
This should help you solve the problem with all the registries that are broken or missing.
__
Regards
Mahesh Babu
