I just finished a game I attended and went online. A few minutes later, the text “exception wlmerger exe bad image” appeared on a paper titled “Windows – Dangerous Image”.I have never seen this error and I do not even know what it means because I am not a technical assistant for a laptop. So what should I do?
Fixing Wlmerger Exe Bad Image
Hello, An incorrect image error occurs when the system method is suspended or a corrupted file has an impact on the system. To limit this difficulty, we recommend that you simply run a System File Checker (SFC) tool to detect and repair damaged files on your laptop. To be on the safe side, we recommend that you simply start your laptop in safe mode.
