FL Studio error while compiling the song
Hello, I use windows 7. I am using FL Studio for 6 months now.. But my FL studio gives error while rendering a track. I can't compile a full song with this software. It's making huge trouble. What should I do? Should I delete the program or what? Help Please
Best Answer by Sharath Reddy
Answered By 0 points N/A #111452
It would be great if you specify the exact error message you are getting while rendering or compiling a song in FL Studio. You are asking if you should remove it or not, you can try to uninstall it completely and then download and install FL Studio from the link below:
https://www.image-line.com/flstudio/
There are many added new features available on this version and will surely help you on compiling your song.
Answered By 590495 points N/A #111453
I haven’t used FL Studio yet because I’m quite familiar with using Cool Edit Pro and it is also an audio editing application. Almost all audio editing applications have similarities. They only differ in the amount of plugins they have. Make sure that the way you edit your music is right and that you have enough resources on your computer for the application to use. If it is your first time to use FL Studio, read and understand carefully the instructions in the help section of the application. It contains all the pointers on how to effectively render a track, edit, make some cut and add effects and saving it for the final output.
Make sure that your current version of FL Studio is really compatible with your operating system. You may also want to try upgrading it to FL Studio 10.0.9. You may visit https://fl-studio.en.softonic.com/ and download the demo version.
