Flash media server for Android 3 OS
I still have an Android 3 on my phone and I am wonder if, per chance, any Adobe flash media server versions support Android 3 or maybe even 2.4? Thanks!
Hello Helemarmstead,
Adobe Flash Player 10.2 can be downloaded for Android versions 2.2 (Froyo) and 2.3 (Gingerbread). But your phone needs to have some hardware requirements like WVGA (800*400) Screen, a processor with 800MHz or faster. You can install this Adobe Flash Player 10.2 for Honeycomb (Android 3.0.1), but this is still in a Beta version.
The Adobe Flash Player version is supportive on Android 3 and I would recommend you that you should update you device with Flash Player version. If you have Android 2.x and Android 3.x devices with Flash Player 11.1.111.31 or earlier versions then you should update the plugin to 11.1.111.32. You can also check it from your phone's settings. The update process is recommended by the company. I hope you have cleared your issue.
