Hello!
After I did update to the latest version of Adobe Flash Player (10.3), videos from YouTube do not appear as they should. All I can see is a green box. I can see the video only after I switch from 480p to 720p or 360p. And after that I can switch again to 480p and it works fine. Do you think it is because of the new Flash Player or because of Direct X or video card? Because this happens only since I've installed the latest version.
Thanks,
Dorel.
Flash Player (10.3) – video error
The browser might also have problem, have you tried uninstalling your web browser then reinstall it with a much updated one. Also try different web browser to see if the same problem exist with a different browser. There might also be a problem with hardware acceleration so you might want to disable this feature. Its about mixing this separate solutions to provide a result and identify which works for your system.
The 10.3 version of the flash player works fine with me but every time I have a problem with videos playing on the web, I just simply do this things to solve my problems.
I don’t think that problem is with Flash Player. It’s more likely caused by your web browser. Since you encounter this problem with YouTube, make sure you are using the latest version of your browser. Try downloading the latest version of your browser from the following:
Also, make sure Flash Player is up-to-date. Download the latest version from here:
