Is Flash player 11 crashing my browser?
I recently used Flash player 11 and since then whenever I load any webpage my browser crashes.
Is it possible that my browser crashes due to Flash player?
Hey Joey Fergus!
There are several reasons due to which your browser caused crashed. First of all make sure that Adobe Flash Player is properly installed. Download the latest and new Adobe Flash Player from https://get.adobe.com/flashplayer/. Close your browser and install it. Once the installation is complete, Run your browser again, you will not face this error again.
Secondly there can be some viruses that do not allow Adobe Flash Player to work properly. Install any antivirus and make sure that all your system is cleaned from viruses.
Run your browser again, your browser should not crash now.
Tunacao Caaron.
Hi, Joey,
i have a good solution for you. you can disable your built in flash or you can turn off your OS flash installation. Or, after turning off your all extensions try to enter on a flash based site. or, finally, you can reinstall your browser to make it compatible for your version. Thanks.
