Flash player for blackberry curve
Hello guys!!!!!!!!!!
I want to watch website video on the website in my BlackBerry. Is there any Adobe Flash Player or any other Flash Player for BlackBerry curve? My Handheld software OS is 4.2.2.
Hi there,
To watch videos on the internet on your BlackBerry you'd have to upgrade your Operating System. I don't think your BlackBerry's Operating System can support that feature.
But if you need a Flash Player, all you have to do is go to the BlackBerry app world, search for Flash Player and download it from there. I hope I've answered your question.
For most of the older BlackBerry browsers flash is not supported. But you can view YouTube movies and Dailymotion movies if your Handheld Software OS is 4.5 or above most people still have 4.2.2. But there are alternative softwares that you can use for this purpose. You can just simply search it using Google with your model of the mobile.
Flash Player is only supported in the BlackBerry OS 4.5 or above. But you can alternatively try for other software at the BlackBerry app world or you can upgrade your BlackBerry software to a newer version through updating it at the BlackBerry Update Center.
Sometimes you may able to install Flash Player after upgrading the software. Also you can find many other alternative software through a Google search to use as an alternative to a flash player.
